Layers of zirconium abrasive cloth, angled on a supporting plate and lasting up to 10 times longer than conventional fibre discs. As the material wears away it exposes a new, fresh face of abrasive therefore achieving much higher material removal. For use on wood, metal, painted surfaces and masonry. These are particularly effective for rust removal and general finishing. 115mm diameter, 22mm bore.
Disc Diameter 115 mm
Abrasive Grit 40
Web Attribute Set Angle Grinder Discs
EAN Barcode 4038595530660
