This industrial 115mm grinder has a slim barrel grip for easy handling. A robust labyrinth construction protects all ball bearings from dust and debris. The armature is coated with a protective zigzag varnish and a field coil that is covered with powder varnish to protect the motor from dust and wire breakage, ensuring maximum durability for masonry cutting.
Supplied with a diamond blade, side handle and case.
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 96 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 85 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Motor Power 720 W
Voltage 230 V
Web Attribute Set Angle Grinders
