The MEXCO GPX10 Concrete Diamond Blades are engineered for reliable cutting across a broad range of general-purpose building materials. Designed as a cost‑effective option, the GPX10 provides dependable performance for users who need a versatile blade capable of handling the most commonly used non‑abrasive materials.
To ensure durability and consistent cutting efficiency, MEXCO has developed this blade with a high diamond concentration and premium‑quality components. This makes it suitable for materials such as reinforced concrete, hard limestone, and concrete paviours.
Segment Height: 10mm
125mm diameter bore 22.3mm, suitable for 125mm angle grinders.
Web Attribute Set Angle Grinder Discs
EAN Barcode 5060093860023
