Unlock stuck parts fast with Fast Release Penetrant. Formulated to perform in temperatures from ‑20°C to +90°C, it rapidly breaks through rust, corrosion, and grime to free seized components with ease. Safe for use on metal, alloys, rubber, plastic, and most painted surfaces, it’s the ideal solution for restoring movement and keeping mechanisms working smoothly. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.
Web Attribute Set Lubricants & Cleaners
EAN Barcode 5032227443488
