If you have turned any of our wine bottle stopper kits, you will appreciate the usefulness of this simple device. After drilling your chosen blank and securing the screw from the kit into it, you simply screw the blank onto the arbor. With tailstock support, turn the required shape using the diameter of the nylon washer as a guide. When you are happy with the profile, remove the tailstock support and clean up the end of the stopper and finish as required. Complete the assembly of the kit and stand back and admire your masterpiece.
Made in Britain Yes
Morse Taper 1 MT
Intended Use Aids with turning a wine bottle stopper kit.
Web Attribute Set Drive Centres
EAN Barcode 5052511010172
