The addition of decorative beads can add interest to your furniture projects but it is not easy to apply a bead set in from the edge of a rail using a router. The traditional method was by using a scratch stock, but by using this cutter and a router you will tackle the job faster with consistent results. With a 1/2 shank 76mm long this beading cutter will allow you to position your beads inset from the rail edge producing some attractive design options. Also useful for producing tongue and groove boarding with a vee groove.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 16 mm (5/8")
D = Overall Diameter 22.2 mm (7/8")
R = Radius 3.2 mm (1/8")
Web Attribute Set Beading & Reeding Router Cutters D: 22.2 R: 3.2 X: 16
EAN Barcode 5052511054022
