When fitting kitchen worktops using a worktop jig, it is necessary for the router cutter to be long enough to extend below the bottom of the worktop but retain a sufficient length of shank in the router collet. This can be difficult to achieve with some routers and when you add an extension to the router such as a sub-base a long shank is needed to provide sufficient protrusion from the base. It's critical that the router bit is inserted to the K Line as moving away from the line causes instability. With this in mind we have introduced a worktop cutter featuring a longer shank than usually found on this type of cutter. This ensures you have enough reach to cut safely through the work piece. These cutters also feature a bottom cut insert for efficient plunge cuts. 50mm depth of cut, 12.7mm diameter and 107mm overall in length.
Axcaliber
Axcaliber Kitchen Worktop Cutter (Long Shank)
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 51 mm (2") |
| D = Overall Diameter | 12.7 mm (1/2") |
| Pack Quantity | 1 |
| Web Attribute Set | Straight Router Cutters D: 12.7 X: 51 |
| EAN Barcode | 5052511054176 |
