Axcaliber router cutters for use with Leigh 'D' series and Leigh Superjigs. The cutters can also be used for sliding dovetails and carcase construction. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength. A finely ground edge ensures a durable efficient cutter and a thick PTFE coating reduces the build up of resin.
Axcaliber
Axcaliber Straight Cutters for Leigh Dovetail Jigs
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 31.75 mm (1.1/4") |
| D = Overall Diameter | 12.7 mm (1/2") |
| Leigh Part No. | 160 Web Attribute Set: Straight Router Cutters Router Cutter Type: Straight twin flute D: 12.7 X: 31.75 |
| EAN Barcode | 5052511048830 |
