This is the ideal companion to the bench top edgebander and edgebanding trimmer. Anyone who has used edgebanding will know how difficult it is to get a perfectly trimmed end. With this tool a single press down on the handle operates the blades in a shearing action. The blades are reversible so when the cutting blade becomes dull simply change places with the anvil blade. The end trimmer cuts banding or veneer up to 0.5mm thick with a maximum cutting width of 54mm.
Axminster Edgebanding End Trimmer
| Plug Fitted | UK 3 pin plug |
| Web Attribute Set | Edgebanders Portable |
| EAN Barcode | 5052511026340 |
