A set of three accurate, high quality high speed steel (HSS) 1.3/4 slitting saw blades, with a flat chisel edge. Supplied complete with a 3/8 pin type mounting arbor. The widths are 1/32, 1/16 and 3/32. Best suited for use in a mill, but can be used in a lathe when the workpiece is held in a vertical vice/slide.
Web Attribute Set Milling Cutters
EAN Barcode 5052511049301
