Steadies are used to give support to long components that may flex whilst being machined. The fixed steady is fastened to the bed and may be used to support the outer end of the machined section, or used instead of the tailstock. The steady has a 40mm work capacity.
Axminster Engineer Series SC4 Fixed Steady
| Web Attribute Set | Lathe Accessories |
| EAN Barcode | 5052511027194 |
