Supplied in matched pairs these hardened and ground Vee blocks are accurate enough for use in layout work and robust enough to be used in machining operations. Dimensions are: 37 x 37 x 50mm.
Overall L x W x H 37 mm x 37 mm x 50 mm
Web Attribute Set Vee, Gauge Blocks & Angle Plates
EAN Barcode 5052511010424
