This Axminster Magnetic Hose Coupler Kit provides a quick and convenient way to connect a single dust extraction hose to three machines. Using a self-aligning magnetic connection, the hose can be moved easily between extraction points without the need to wrestle with tight push-fit connections. The secure magnetic coupling helps maintain efficient airflow while making it quicker to change from one machine to another.
The kit contains one 100mm male magnetic coupler, three 100mm female steel-ring couplers, three 100mm rubber cuffs and one 100mm retaining clip. The male coupler is fitted to the dust extraction hose using the supplied clip, while each female coupler is mounted to a machine using the rubber cuffs. Manufactured from durable workshop-grade materials, the components are designed for reliable everyday use and provide a straightforward way to equip three machines with compatible magnetic connection points.
Designed by Axminster for practical workshop use, this kit offers a simple way to expand a magnetic dust extraction system across multiple machines. Suitable for professional workshops and home woodworkers alike, it helps improve workflow by making dust extraction connections faster, easier and more consistent.
EAN Barcode 5052511147038
