Axminster SC2/C2 metric thread dial indicator, a handy device to enable accurate threads of 0.5mm or 1.0mm pitch to be cut. With a thread indicator you will always start your thread cutting in the same spot on each cut. For 1.5mm pitch lead screws. N.B. You will need to remove the lead screw swarf cover on later SC2 machines.
Web Attribute Set Lathe Accessories
EAN Barcode 5052511027149
