This marking gauge is made of hardwood with a protective oiled finish giving it a much better feel to it. Underneath the knurled brass locking screw is a pressure pad to protect the stem from bruising. The head is inlaid with two brass wear strips ground and polished flush with its surface. We hope you have as much joy using this tool as we did developing it. Max capacity 145mm.
Web Attribute Set Marking Gauges
EAN Barcode 5052511089697
