Pen turning made easy
The ideal starter kit for pen making, this Pen Turners Set is designed for beginners and those looking for light use. It includes all the essential tools you need to start crafting beautiful pens with ease.
Three metal carving or chisel tools with silver blades and light wood handles resting on a wooden surface.
M2 HSS blades
The blades are manufactured from M2 high-speed steel, ensuring greater durability and extended lifespan.
A close-up of a woodturning chisel with a light wood handle engraved with the brand name 'PERFORM' being used in a workshop to shape a piece of wood on a lathe.
Perfect for pens or small projects
An ideal starter woodturning pen set, it includes three essential tools to help you craft your first pen with success.
Three wood carving chisels with light natural wood handles and silver metal blades, each engraved with the brand name 'PERFORM.', arranged diagonally on a wooden surface.
Set includes...
Deep flute gouge - Ideal for roughing to size
Oval skew - Perfect for finishing cuts
Parting tool - Excellent for end grain square cuts or sizing
Three woodworking chisels with light natural wood handles engraved with the brand name 'PERFORM' and silver metal blades, resting on a wooden surface.
Comfortable handling
Each chisel comes with 200mm hardwood handles for comfortable and easy handling.
This Perform HSS Woodturning Chisel Set (3pc) is ideal for pen turning or other small projects and makes a great beginner woodturning tool set. These woodturning tools come as a set of 3, with M2 HSS blades and 200mm hardwood handles. M2 HSS holds a sharp edge for longer than typical carbon steel.
The set comprises of:
6.3mm (1/4) deep flute gouge for roughing to size
12.7mm (1/2) oval skew for finishing cuts
3.2mm (1/8) parting tool for end grain square cuts
Blade length of the gouge is 110mm, whilst the length of the skew and parting tool is 95mm.
Web Attribute Set Woodturning Tools - Sets
EAN Barcode 5052511143108
