Dual drums, double efficiency
The Axminster AP640DS Drum Sander is a professional dual drum sander that combines speed, precision, and a smooth finish. With dual belts, digital height control, variable feed speed, efficient dust extraction and more, it delivers consistent, high-quality results while taking workshop efficiency to the next level.
Buy with confidence
Dual drum design
Dual drum system
Run coarse and fine grits simultaneously, in a single pass to reduce sanding time and deliver quality results.
Digital height adjustment
Use the digital height adjustment scale to ensure exact worktable positioning every time, removing guesswork and improving repeatability. The large adjustment handle makes fine height changes quick and accurate.
Variable conveyor speed
The variable conveyor speed (0-4.6m/min) allows you full control over material feed rate, so you can achieve excellent sanding performance every time.
Heavy-duty cabinet stand
The heavy-duty cabinet stand ensures excellent stability and long-term durability, so you can get the most from your sander.
Balanced sanding drums
Dynamically balanced sanding drums minimise vibration for smooth, consistent operation and result in quality finished timber.
Dust extraction
Dust extraction
Two 100mm dust outlets provide efficient extraction when connected to a suitable extractor. The outlets remove dust with ease, leaving your workspace clear.
Get the best out of your AP640DS Drum Sander
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Professional AP640DS Drum Sander is a heavy duty dual drum sanding machine designed for workshops that demand speed, accuracy, and a flawless finish. With its dual-drum system, robust cabinet stand, 3kW motor and precise digital controls, the AP640DS Drum Sander delivers exceptional results across a wide range of materials including wood, plastics, and similar materials.
The advanced dual drum sanding system allows you to run 80 grit and 120 grit belts simultaneously, combining coarse material removal and fine finishing in a single pass. This dramatically reduces sanding time while delivering consistent, professional-quality results, especially with the power of the 3kW motor.
A digital height adjustment scale ensures exact worktable positioning every time, removing guesswork and improving repeatability. The large, ergonomically designed adjustment handle makes fine height changes quick, smooth, and accurate, even when working with demanding materials.
The AP640DS Drum Sander is built on a solid, heavy duty cabinet stand, providing excellent stability and long-term durability in professional environments. Dynamically balanced sanding rollers minimise vibration, resulting in smoother operation, reduced machine wear, and a superior surface finish.
The variable conveyor speed (0–4.6 m/min) allows full control over material feed rate, ensuring optimal sanding performance for both aggressive stock removal and fine finishing. Two 100mm dust extraction outlets efficiently remove dust and debris, keeping the workspace cleaner and improving air quality.
N.B. Drum sanders are used as part of the finishing process, they are not intended to be used as a planer/thicknesser or for significant stock removal. A drum sander does not replace a planer/thicknesser and vice versa. Drum sanders are intended to be used with already planed and thicknessed material. Overall a planer/thicknesser is meant to dimension timber, the drum sander to finish it.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Please note, if you require an EU plug, please ensure you purchase 113776
Dust Extraction Outlet 2 x 100 mm
Feed Speed 0 to 4.6m/min
Overall L x W x H 1,220 x 860 x 1,320 mm
Power 3.0 kW
Rating Frequent Use
Table Size 660 x 625 mm
Min Extraction Airflow Required 1,500 m³/hr
Sound Power Level LwA [Uncertainty K] 87 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Drum Sanding Machines
EAN Barcode 5052511142286
  • UK Mainland - £70
