Axminster Professional
Axminster Professional 300mm Extension Bed
SKU: 111888
€68,00
  • Suits the AP530WL lathe
  • Provides 805mm between centres
  • Supplied with fixing bolts and rubber feet
This extension bed is designed to suit the AW530WL Woodturning Lathe. It increases the distance between centres to 805mm between centres. It is perfect for turning larger projects and workpieces that need the extra capacity. Supplied with fixings bolts and rubber feet to match your lathe.
Web Attribute Set Woodturning Lathe Bed Extensions
EAN Barcode 5052511136391
