Axminster Professional
Axminster Professional AP122QC Quiet Compressor
SKU: 113341
€425,00
  • Quiet operation for use in noise sensitive areas
  • 106 l/min air delivery for consistent performance
  • Oil-free, low maintenance design
  • Anti-vibration pad reduces noise and movement
  • Durable 22 litre power coated tank
  • Compact 550W motor for portable power
The Axminster Professional AP122QC Quiet Compressor is a compact, portable unit designed for reliable performance in noise-sensitive environments. Delivering 106 l/min of free air, it provides consistent output while operating at a low noise level - ideal for use in customers’ homes or shared workspaces without causing disturbance.
Built for durability, its robust construction helps minimise downtime so you can keep working longer. An anti-vibration pad further reduces noise and movement during operation, while the oil-free design keeps maintenance to a minimum, saving you time and effort. The powder-coated tank resists wear and corrosion, whilst the inner surface is coated with epoxy to ensure a long-lasting, professional finish.
Powered by a 550 W motor, the compressor features a 22-litre tank capacity, offering a practical balance of portability, performance, and reliability. The motor features a built in overcurrent protector and overheat protection to ensure safe and reliable operation.
The compressor is also fitted with an air regulator, pressure gauge, check, solenoid and safety valves for ultimate control. Equipped with euro style fittings.
Overall L x W x H 600 x 295 x 570 mm
Power 550 W
Rating Frequent Use
Cable Length 2 m
Sound Pressure Level LpA [Uncertainty K] 64 dB(A)
Plug Fitted UK 3 pin plug
Web Attribute Set Air Compressors
EAN Barcode 5052511142361
