Axminster Professional
Axminster Professional AP1550BN Brad Nailer 18G 15-50mm
SKU: 107614
€63,00
  • Drives 18 gauge T-headed brad nails from 15mm to 50mm long
  • Convenient; trigger or bump operation
  • Extremely reliable in busy workshop conditions
  • Supplied with 1/4 BSP Quick Release bayonet fitting
The most popular air nailer in our range, this lightweight, trade-rated nailer drives 18 gauge T-headed brad nails from 15mm to 50mm in length and with its low air consumption can be used with any of the smaller 25-litre capacity compressors.
It can be used with standard trigger firing or in bump mode where, with the trigger engaged, a nail is delivered each time the safety stop is depressed, useful for fast fixing. The gun is easy to load and has a re-load sight so that the operator can see when the magazine is empty. Other useful features are the depth adjustment which controls the depth to which the nail is driven, the adjustable air exhaust outlet and the quick release front cover to give easy access for clearing jammed nails.
A 1/4 BSP male Euro bayonet fitting is provided in the back of the tool for direct connection to the airline using quick release bayonet fittings. Supplied in a plastic storage case.
Inlet 1/4 BSP
Overall L x W x H 250 mm x 70 mm x 250 mm
Rating Frequent Use
Web Attribute Set Air Nailers & Staplers
EAN Barcode 5052511125104
