Axminster Professional
Axminster Professional Dado Blade Table Insert 305mm
SKU: 110644
€24,00
  • Precision and accuracy in dado cuts
  • Enhanced stability for workpieces
  • Versatile for various joinery types
  • Improved safety during operation
  • Durable construction for long-lasting use
Made from high-quality materials, the Axminster Professional Dado Blade Table Insert 305mm facilitates the creation of wide, flat-bottomed grooves, known as dado cuts, on your table saw. This insert replaces the standard throat plate, offering enhanced support and stability for your workpiece for more controlled and safer cutting operations. It also ensures that your dado cuts are perfectly aligned and clean, reducing the risk of tear-out and splintering.
The dado blade table insert is ideal for creating various types of joinery, including grooves, dado joints, and rabbets, making it a versatile addition to your woodworking toolkit. By securely holding the dado blade set in place, the insert minimises the risks of accidents and enhances overall safety during operation within professional woodworking environments.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511133307
