Axminster Professional
Axminster Professional Dado Blade Table Insert For AP254SB
SKU: 109598
€22,00
  • Table insert for AP254SB when using dado blade
  • Replaces standard table insert
  • Aluminium with 25mm wide slot
This table insert fits the AP254SB Professional Saw Bench. It is required when using a dado blade, replacing the standard insert. The slot is 25mm wide to accommodate the dado blade. It is used with the saw blade set at vertical only. Made from aluminium.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511131471
