The Axminster Professional SD3886B bandsaw combines heavy-duty construction with precision engineering to deliver power, accuracy, and reliability for demanding workshops.
Featuring a 546 x 400mm cast iron table, this bandsaw provides an impressive 300mm depth of cut and 447mm throat capacity, making it ideal for heavy duty projects. The balanced 450mm cast iron blade wheels and solid cast iron table minimise vibration for smoother, more consistent results when working with materials of all sizes.
Switching from heavy rip cuts to fine, detailed work is effortless thanks to the Hi-Low rip fence, which offers excellent flexibility and control. Quick-release blade tensioning ensures fast, simple setup and adjustment.
Powered by a robust 1.5kW motor, the SD3886B bandsaw handles demanding cuts with ease. The rack and pinion table tilt mechanism allows for precise and rapid angle adjustments, further enhancing versatility.
For safety and cleanliness, micro-switched doors automatically stop the blade within 10 seconds of opening, while twin 100mm dust extraction ports help maintain a clear, dust-free workspace.
Supplied with a mitre gauge, this versatile bandsaw is ready for a wide range of woodworking applications.
