Axminster Professional
Axminster Professional SD400PS 3200mm Panel Saw 3ph
SKU: 113325
€8.650,00
£70 Large Delivery within 14 working days*.
  • Panel saw ideal for sizing, ripping and producing precise cuts
  • Heavy duty construction to reduce vibration
  • 400mm blade, spinning at choice of 3 speeds
  • Sliding table to offer smooth, accurate movement for large pieces
  • Powerful 5.5kW motor to deliver clean cuts
  • Fully adjustable overhead crown guard
The Axminster Professional SD400PS 3,200mm Panel Saw is a highly versatile machine, ideal for sizing sheet materials, ripping solid, thick timber and producing precise angled cuts for complex joinery. Built with a heavy duty cast iron and steel construction, the saw delivers exceptional stability and vibration free performance, ensuring consistently accurate results.
A large 3,200 x 418mm sliding table, provides excellent support and smooth movement for a wide range of workpieces. The sliding table offers a full 3,200mm travel past the blade, making it easy to handle full-size sheets. The main cast iron table measures 1,020 x 690mm offering ample working space at a comfortable working height of 900mm.
Fitted with a 400mm blade running at a choice of 3,000, 4,000 and 5,000rpm, the saw can cut up to 125mm at 90° and 85mm at 45°, with smooth and precise tilt adjustment from 0-45°. This makes it equally capable of cutting thick boards and carrying out complex joinery work. Power comes from a robust 5.5kW motor, delivering clean, efficient cuts with ease across a variety of materials.
The saw unit and motor assembly are housed within a reinforced steel cabinet, isolating mechanical stress from the cast iron table. This design ensures the table remains flat over time, maintaining cutting accuracy even under heavy workloads. A heavy duty aluminium extruded crosscut fence supports workpieces up to 3,900mm in length and includes two precision machined cast aluminium repeat stops for fast, accurate and repeatable cutting.
With a ripping capacity of 1,250mm and a sliding table stroke of 3,200mm, handling large panels is straightforward. The motor drives a dedicated 120mm scoring blade with a 20mm bore, producing flawless, chip free finishes on veneered and laminated panels.
For safety and dust control, the SD400PS panel saw is equipped with a fully adjustable overhead crown guard that provides clear visibility of the cutting area while capturing dust at source. A 100mm dust extraction outlet requires an airflow of 830m³/hr, helping to maintain a cleaner, safer working environment.
Whether you're upgrading from your old saw or expanding your production capabilities, the SD400PS panel saw delivers the cutting depth, table size, and motor power required for high volume, precision woodworking.
Blade Tilt 0 to 45
Dust Extraction Outlet 100 mm
Max Depth of Cut @ 45º 85 mm
Max Depth of Cut @ 90º 125 mm
Max Width of Cut with Fence 1,250 mm
Overall L x W x H 6,700 x 5,410 x 1,500 mm
Power 5.5 kW
Rating Frequent Use
Table Height 900 mm
Table Size 1,020 x 690 mm
Blade Diameter 400 mm
Min Extraction Airflow Required 830 m/hr
Sound Power Level LwA [Uncertainty K] 85.7 dB(A)
Blade RPM 3,000, 4,000, 5,000 rpm
Sound Pressure Level LpA [Uncertainty K] 100.7 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Panel Saws
EAN Barcode 5052511142521
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
  • UK Mainland - £70
