At 150mm diameter, these jaws allow you to reverse chuck smaller workpieces quickly and securely at the turn of a chuck key. The conical rubber buttons pull your work gently back against the aluminium jaw plates without damaging its edge. You can use them externally or internally. A series of tapped holes offers you a variety of diameters. It is also possible to grip odd shaped pieces using different holes. The jaws come with rubber buttons. They will fit the GK88, GK100, SK100 or SK114 chucks. As an alternative to using the buttons, stacking turn studs are available as an optional extra. They form an excellent primary holding method for all manner of round or square blanks and, give a very secure grip. The studs can be used singly or doubled up using the longer bolts supplied. Recommended maximum speed 1,500rpm. These jaws are made from aluminium making them lightweight. As with all Axminster Woodturning Dovetail Jaws they simply bolt onto the Accessory Mounting Jaws.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use Reverse chuck smaller workpieces quickly and securely.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511065288
