Wood jaw plates are a versatile aid for attaching and turning wooden jaws to your own design to your woodturning chuck. Wood Jaw Plates offer an ideal solution for reverse chucking a turned bowl in order re-work the back or remove any evidence of initial workholding. Made from stainless steel to protect against corrosion, the SK100 Wood Jaw Plates consist of four pre-drilled steel quadrants. Use standard woodscrews to mount self-made wooden segments. Once attached these wooden segments, turned the wooden jaws to whatever best suits the workpiece. For example grooves to grip the rim of a bowl. These 100mm plates would be suitable for wooden jaws between 250mm to 300mm diameter. An optional long chuck key is available giving extra reach behind these jaws.
Suitable for the GK88, GK100, SK100 and SK114 chucks. As with all the Axminster Woodturning Dovetail Jaws, they simply bolt onto the Accessory Mounting Jaws.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For reverse chucking a turned bowl in order to re-work the back.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511044665
