These collars clamp onto either end of any Axminster Woodturning tool rests; once secured, they form stops to limit the travel of your turning tool along the rest. The collars can form a useful stop marking your chisel's position when performing repeat turning. The split collar design ensures there is no danger of damage or burring of the tool rest. Fitting one of these collars prevents your chisel accidently sliding off the end of the tool rest. Size 45mm outer diameter with 19.05mm (3/4
Axminster Woodturning Tool Rest Stops (Pair)
| Web Attribute Set | Woodturning Lathe Tool Rests |
| EAN Barcode | 5052511120284 |
