The AW2260S planer thicknesser with its spiral cutter block is a pleasure to use and delivers excellent results. The spiral cutting block has twenty four, four sided, solid carbide cutters arranged in a helix. The shear cutting action produces a silky smooth finish. There is a complete lack of planing ripple as often found using traditional straight knives. Each cutter’s edge will last around 10-20 times longer than a HSS knife and each cutter has four edges. When a cutter does become dull, take the torx driver supplied and turn the cutter through 90
When surface planing, a long rigid alloy fence supports your work. The fence is easily adjustable with stops for 90
Please note, this machine is fitted with a 1.5kW motor, allowing it to run from a standard domestic 13A socket without the need for a more costly 16A electrical supply installation. If you require an EU plug, please ensure you purchase 113776.
