Hermes
Hermes BW 115 Abrasive Belts 150 x 2,260mm
SKU: 300414
£10.98
£9.15 Excl. VAT
  • Aluminium oxide abrasive on E-weight paper backing
  • Semi-open coating, antistatic resin bonded, reduces clogging
  • Economical sanding for excellent results on all types of wood
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW115 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW115 is an excellent multi-purpose abrasive for use with powered sanders.
To fit Jet OES-80 CS oscillating edge sander and the Axminster AT 6X90 oscillating belt sander.
N.B. formally BW110, same abrasive just a code change.
Abrasive Type BW 110
Abrasive Belt Length 2,260 mm
Abrasive Belt Width 150 mm
Abrasive Backing Paper
Pack Quantity 1
Abrasive Grit 80
EAN Barcode 4047915810290
