These Hermes RB377YX 150 x 2,000mm belts are suitable for the Axminster Engineering Series BS-150 Belt Linisher. The RB377YX material is a heavy and semi-flexible aluminium oxide abrasive cloth. The special aluminum oxide grain mix provides high stock removal in the coarse grits and gives a very constant surface quality in the finer grit ranges, the backing is a polyester/cotton cloth which ensures smooth running on our machines. All this makes it a perfect partner for our range of belt linishing machines whether you are using steel, stainless steel, aluminum or other types of non-ferrous metals.
Hermes
Hermes RB 377 YX Abrasive Belts 150 x 2,000mm
| Abrasive Material | Aluminium Oxide |
| Abrasive Type | RB 377 YX |
| Abrasive Belt Length | 2,000 mm |
| Abrasive Belt Width | 150 mm |
| Abrasive Backing | Cloth |
| Pack Quantity | 1 |
| Abrasive Grit | 60 |
| Web Attribute Set | Abrasive Belts |
| EAN Barcode | 4045191485270 |
