The BORA Auto Adjust T-Track Clamp 8mm (5/16) is a versatile, time-saving solution designed to streamline clamping across a wide range of woodworking and workshop tasks. Built to fit standard 8mm (5/16) T-tracks, it provides a secure and reliable hold while reducing the need for constant adjustments, making it ideal for both professional and hobby use.
Featuring an intelligent auto-adjust mechanism, the clamp automatically adapts to different material thicknesses, maintaining consistent pressure throughout your work. This helps improve accuracy, reduce setup time and keep projects moving efficiently. The 360-degree rotating clamp head allows for flexible positioning, making it easier to handle awkward setups or confined working areas.
Constructed with a durable 8mm (5/16) T-bolt for dependable performance, this clamp is well suited to repeated, heavy-duty use. Whether used for routing, sanding, assembly or general bench work, it provides a stable and adaptable clamping solution across a variety of applications.
EAN Barcode 9341231064302
