The BORA Auto-Adjust In-Line Dog Clamp is engineered to streamline workflow and deliver consistent results without the need for frequent manual adjustments. Designed for woodworking and machining tasks, this clamp maintains steady, reliable pressure across materials of varying thicknesses, helping you achieve precise, repeatable results with minimal effort. Its in-line design makes it particularly effective for controlling longer workpieces and keeping projects stable throughout the process.
At the heart of the clamp is a hardened steel push rod, built to deliver dependable clamping performance across materials up to 3.75 inches thick. This robust construction ensures even pressure distribution, reducing movement and improving accuracy during cutting, assembly or finishing tasks. The innovative split dog peg provides a secure and stable fit within compatible dog-hole systems, allowing for confident use on a wide range of work surfaces.
When used on its own or paired with BORA Dog Fences, the clamp is especially effective for securing long panels, aligning workpieces and stabilising larger setups. Its ability to maintain consistent pressure without constant readjustment helps save time, making it a valuable addition to any workshop where efficiency and precision are key.
BORA Tools is recognised for producing practical, innovative solutions that improve efficiency for woodworkers, tradespeople and DIY users. With an emphasis on durability, adaptability and performance, BORA tools are designed to simplify workshop processes while delivering reliable, professional results.
The clamp is capable of handling materials up to 3.75 inches thick and features a hardened steel push rod for consistent pressure. Its in-line design reduces the need for readjustment, while the split dog peg ensures a secure fit within standard dog-hole systems. It is also fully compatible with BORA Dog Fences for expanded clamping and stabilisation options.
Supplied as a single BORA Auto-Adjust In-Line Dog Clamp with integrated split dog peg and hardened steel push rod, ready for use with compatible worktops and clamping systems.
EAN Barcode 9341231064838
