UJK Twist Dogs are of a unique design. Their 25mm long spigot is a snug fit in the 20mm diameter dog holes of the UJK MultiFunction Workbench and the Festool MFT bench. The Twist Dog’s unique feature is a pin through the spigot. This pin securely locks the Twist Dog into the specially drilled holes of the UJK Multifunction Workbench. Made from hard acetate plastic (the same material as shatterproof chisel handles), these dogs will not damage cutting edges in the case of accidental contact. Twist Dogs are highly accurate and acetate plastic a very stable material. The upper portion is a precise 25mm diameter with a 40mm working height. Twist dogs use the alignment of the UJK MultiFunction or Festool MFT table’s holes to set up fences, guide rails or workpieces. They let you use the CNC precision of the table to ensure your results are as accurate as the CNC machine itself.
Made in Britain Yes
Web Attribute Set Bench Dogs & Bench Fittings Working Height: 40 mm
EAN Barcode 5052511072866
