These wedges are part of the UJK Cam & Wedge set available separately. They have great potential in many workholding situations.
The wedges taper from 32mm to 27mm over a length of 200mm. They are CNC cut from 20mm thick HDF Valchromat. This material is very durable and easily tough enough to withstand gentle tapping with a hammer to lock the wedge. Using two wedges acting against each other ensures the applied force is at 90 to the edge of the workpiece.
Valchromat is certified by the Pan European Forest Council (PEFC).
Made in Britain Yes
Intended Use Used in conjunction with dog holes to hold work to a workbench.
EAN Barcode 5052511108756
