This generous sized storage unit fits the Axminster 1700, Diamond D1 and D2 benches. One half is open with a single full depth shelf. The other half has a full height cupboard. With this unit you can keep your most frequently used tools close to hand. At the same time, tools not in use are out of harm’s way. Built from beech effect laminate boards, the storage unit is a snug fit and adds rigidity to your bench. Supplied flat packed for self assembly. Size 1,000 x 430 x 500mm, weight 25kg.
Axminster Storage Cupboard For 1700, D1 & D2 Benches
| Overall L x W x H | 1,000 mm x 430 mm x 500 mm |
| Web Attribute Set | Woodworking Benches |
| EAN Barcode | 5052511141043 |
