This workbench provides enough space for two people to work together at the same time. Made from slow grown European beech and birch, it is extremely robust. Its construction uses 2x 40mm thick slabs of laminated beech, each measuring 1,800mm x 250mm. A central shallow recess of 330mm width runs along the full length. This gives a bench size of 1,800 x 830mm. There is the provision to add a 180mm (7
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
