The Pony E‑Z Clamp™ Heavy Duty Folding Worktable is a versatile and robust solution for all your project needs. Featuring two E‑Z Hold® bar clamps and four bench dogs, this worktable can support up to 226kg (500 lb.) as a table and up to 453kg (1,000 lb.) as a sawhorse. Its 2‑in‑1 design allows for quick and easy conversion between a worktable and a sawhorse, making it perfect for tackling a variety of projects.
The E‑Z Hold® bar clamps can be fastened directly to the worktable/sawhorse, providing greater flexibility by holding items vertically or horizontally. With a hassle‑free breakdown and folding mechanism, moving the worktable from one job to another or from the basement to the garage is a breeze. Additionally, the 6-position height-adjusting feature enables you to work at different levels, while the built‑in shelf offers convenient storage for tools and materials, saving space and keeping everything within reach. Maximum working height of 890mm but is adjustable between 765mm to 890mm.
Specifications:
Height: 88.9cm (35)
Clamping Span: 74.9cm (29.1/2)
Tabletop Bench: 78.7 x 63.5cm (31 × 25)
Dog Hole Size: 19mm (3/4)
Maximum working height: 890mm, however adjustable between 765mm to 890mm
Table Size 78.7 x 63.5cm (31 x 25)
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 44295060011
