This sturdy Scandinavian bench has a hard Nordic birch top 1340 x 500mm with a working height of 860mm. It comes with two vices. There are four mounting locations for the vices allowing you to configure the bench to best suit your needs. Both vices can be mounted on the front for heavy-duty clamping or at either end as a tail vice.
A double row of 19mm dog holes run from each of the four vice locations, giving an endless opportunity to clamp your work. Four steel bench dogs with a protective plastic coating are supplied as standard. The bench dogs are reversible for thin work pieces.
This Nordic bench is supplied with the accessory cupboard and drawer unit (0042), giving you plenty of useful storage space.
The optional Holdfast (ST03), makes a useful addition to the 1450.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
