These screws will fit both of the 38mm or 75mm diameter Axminster woodscrew chucks as well as the screw chuck inserts that fit into the C type jaws. They are turned from solid stainless steel, with a special thread form developed for maximum grip in all types of timber. Three thread diameters are available requiring 4, 6.35, and 8mm drill sizes
Made in Britain Yes
Screw Size\Gauge Large (8 mm Pilot Hole)
Intended Use Quick and convenient method for mounting a turning blank on your lathe.
Web Attribute Set Wood Screw Chucks
EAN Barcode 5052511044733
