Fuji’s Replacement Foam Pre‑Filters provide essential first‑stage turbine protection, capturing dust and debris before it reaches the main filter, helping maintain clean airflow, cooling performance and consistent spray quality.
A pack of two genuine Fuji Spray foam pre‑filters designed to fit the air intake of compatible Fuji D6 turbine systems. These filters act as a protective barrier for the turbine motor and primary filtration stage, supporting smooth and reliable operation.
Fuji Spray is a leading manufacturer of high‑performance HVLP spray equipment trusted by professionals worldwide. Their turbine systems and accessories are engineered for durability, clean airflow, and consistent finishing results, supported by a full range of genuine replacement parts to keep systems running at peak efficiency.
Specifications
Genuine Fuji Spray part: 4326‑2
Quantity: 2 foam pre‑filters
Compatibility: Fuji D6 HVLP turbine systems
Function: Captures coarse dust and debris before the main filter
Installation: Quick, tool‑free replacement at turbine air intake
Pair with Fuji’s main turbine filters for complete multi‑stage filtration, ensuring optimal airflow and prolonging the service life of your D6 turbine system
