Kreg Bench Clamp with Bench Clamp Base creates a versatile, movable benchtop clamping station for woodworking, assembly and general workshop tasks. Combining a 76mm Bench Clamp with a rotating Bench Clamp Base, it provides secure workholding wherever you need it.
Featuring Automaxx® Auto-Adjust Technology, the clamp automatically adapts to different material thicknesses without readjustment. An easy-to-use thumbscrew allows precise pressure adjustment, while the extra-large padded clamp face distributes force evenly to protect delicate surfaces. The cast aluminium base mounts quickly into 20mm bench dog holes and rotates through 360° for flexible clamping positions.
Constructed from heavy-duty metal, the clamp offers an 83mm clamping capacity and a 76mm throat depth, making it ideal for joinery, sanding, routing, drilling and assembly work.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Supplied with a 76mm Bench Clamp and Bench Clamp Base, this system is compatible with Kreg Bench Clamps, Clamp Trak, Clamp Vise and the Kreg Mobile Project Center.
