The One Micron Canister Filter is a highly efficient filtration system designed to capture fine dust particles, ensuring a clean and safe workspace. This filter is a key component of the Laguna C|Flux 1 Cyclone Dust Extractor.
The filter is made from polyester spun bond material, which is highly pleated to maximise the surface area and airflow. This design allows the filter to capture dust particles as small as one micron, significantly improving the air quality in your workshop. The canister is fitted to a cleaning paddle (which comes as part of the C|Flux 1 Dust Extractor) which can be rotated using a crank handle to dislodge dust particles from the filter surface, making maintenance easy and efficient. The filter's robust construction ensures durability and long-lasting performance.
Filter Performance 1 micron
Web Attribute Set Filter Cartridges & Bags
EAN Barcode 5052511135738
