WD‑40 Specialist High Performance Silicone Lubricant delivers superior protection against moisture and extreme temperatures, performing reliably from ‑35°C to +200°C. Its clean, non‑staining formula prevents sticking and bonding while guarding surfaces against rust and corrosion. Safe for use on plastic, rubber, wood, and metal, it provides smooth, long‑lasting lubrication across a wide range of applications. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.
WD-40
WD‑40® High Performance Silicone Lubricant 400ml
| Web Attribute Set | Lubricants & Cleaners |
| EAN Barcode | 5032227443778 |
