The Woodpeckers Auto-Line Drill Guide provides a practical solution for drilling accurate, perpendicular holes when a drill press is unavailable or the workpiece is too large to fit on one. Combining a precision drill guide with an adjustable fence and centring system, it helps position holes accurately while keeping the drill bit square to the work surface.
At the heart of the system is a 12.7mm (1/2
The base features laser-engraved centre lines for accurate hole positioning and a V-groove for drilling round stock. The standard opening accommodates drill bits up to 19.1mm (3/4
An adjustable fence system provides edge referencing and can be mounted on any side of the base. The fence offers a standard capacity of 177.8mm (7
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers who need accurate drilling away from the drill press, the Auto-Line Drill Guide offers portable precision for large workpieces, installed components and workshop projects. Supplied with: Woodpeckers Auto-Line Drill Guide, adjustable fence, centring pins, depth stop and hex key.
N.B. Not suitable for use with impact drivers.
