The Woodpeckers Auto-Line Drill Guide Deluxe Kit provides a portable solution for drilling accurately positioned, perfectly perpendicular holes in workpieces that are too large, awkward or inaccessible for a drill press. Combining a precision-guided drilling mechanism with a versatile fence and positioning system, it helps deliver accurate results whether you're working in the workshop or on-site. The Deluxe Kit adds extended fence capability for greater positioning flexibility and repeatable drilling operations.
At the heart of the system is a 12.7mm (1/2) chuck supported by sealed ball bearings and guided by precision steel columns. Teflon-lined guide sleeves keep the chuck travelling smoothly and square to the workpiece, while an adjustable depth stop allows repeatable drilling depths. The quick-release drive shaft is compatible with most corded and cordless drills.
Laser-engraved centre lines on the base simplify hole positioning, while an integrated V-groove provides support for drilling round stock. The standard base opening accommodates drill bits up to 19.1mm (3/4) diameter. By reversing the chuck carrier, holes up to 50.8mm (2) can be drilled using appropriate cutters.
Centring pins allow the guide to be accurately positioned on stock up to 79.4mm (3-1/8) wide, while the adjustable fence system can be mounted on any side of the base for edge-referenced drilling. The Deluxe Kit includes additional guide rods for greater reach and positioning options when working on larger projects.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers, installers and woodworkers who need accurate drilling away from the drill press, the Auto-Line Drill Guide Deluxe Kit provides portable precision for large workpieces, installed components and workshop projects. Warning: Not suitable for use with impact drivers. Supplied with: Woodpeckers Auto-Line Drill Guide, adjustable fence, centring pins, depth stop, standard guide rods, extended guide rods and hex key.
Web Attribute Set Drill Stands
EAN Barcode 0810018203610
