The Woodpeckers Sharpening System provides a precise and repeatable way to sharpen chisels and plane irons using bench stones. Designed to make sharpening easier and more consistent than working freehand, the system combines a stable two-roller honing guide with dedicated tools for accurately setting and checking sharpening angles.
Unlike conventional single-roller guides, the Woodpeckers Sharpening Guide uses two rollers to provide stable support throughout the sharpening stroke. Precision-machined shoulders hold the blade square within the guide, while two roller positions accommodate different tool widths. The outer position suits blades from 3.2mm (1/8
The Sharpening Angle Fixture provides positive reference settings for primary bevel angles from 15° to 45° in 5° increments, together with a 2° micro-bevel offset for each setting. This makes it easy to reproduce the same sharpening angle when returning a tool to the stones. The separate Sharpening Angle Gauge provides quick references for checking common bevel angles before or after sharpening. Corrosion-resistant components make the guide suitable for use with waterstones as well as other suitable bench sharpening stones.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers, joiners and hand-tool woodworkers looking for consistently sharp chisels and plane irons, the Woodpeckers Sharpening System brings greater control and repeatability to bench stone sharpening. Supplied with: Woodpeckers Sharpening Guide, Sharpening Angle Fixture and Sharpening Angle Gauge.
