The Rider No. 69 ½ Block Plane is a compact, one‑handed bevel‑up plane that feels instantly at home on the bench. Balanced, comfortable and purpose‑built for fine trimming and end‑grain work, it blends the low‑angle performance of a 60 ½ with the wider cutting capacity of a 9 ½. Despite its small footprint, the substantial 3.2 mm‑thick blade keeps chatter to a minimum, giving you the stability needed for clean, predictable finishing cuts.
Shaped with input from professional UK woodworkers, the ergonomics have been carefully refined. The angled thumb rest and smooth, domed cap sit naturally in the hand, making the plane easy to control with less fatigue over longer sessions. Its low‑angle setup, paired with the extra cutting width, gives you confident handling whether you’re trimming wide joints or tackling awkward grain.
Built from ductile iron, the body feels solid, smooth and reassuringly durable. The blade’s chamfered edges mimic the profile of a honing‑guide fit, giving you a more secure grip during adjustments and helping prevent slipping. A stainless‑steel Norris‑style adjuster and hand wheel provide smooth, precise control over depth and alignment while resisting corrosion for long‑lasting reliability. The extra‑wide blade—cryogenically hardened M2 high‑speed steel (HSS)—offers excellent wear resistance and edge retention, ideal for fine finishing and trimming difficult grain. A Norris‑style adjuster allows precise depth and lateral tweaks, while the adjustable mouth lets you quickly switch from heavier passes to ultra‑fine work.
Simple to set, intuitive to adjust and satisfying to use, the Rider No. 69 ½ delivers modern reliability with a classic feel. It’s a high‑performance all‑rounder - one of those essential block planes that earns a permanent place on your bench.
