The GSB 12V-15 Combi Drill is compact and light-weight and packs real punch when it comes to power and performance. The GSB 12V-15 drills wood and metal as well as masonry hammer drilling up to 10mm. Weighing just over 1kg, it is the perfect size for all manner of jobs. It features a two-speed gearbox with trigger controlled variable speed. With twenty torque settings, a 10mm Auto-Lock chuck, motor brake, LED work light, battery charge indicator, and softgrip for comfort. Overload, overheating, and deep discharge are prevented by the drill driver´s Electronic Cell Protection. The GSN 12V-15 is without a doubt, a very effective and compact combi drill.
Supplied with two 2.0Ah Li-ion batteries, GAL12-20 compact charger and an S-Bag carry case.
Battery Capacity 2.0 Ah
Battery Voltage 12 V
Rating Trade/Professional
Reverse No
Sound Power Level LwA [Uncertainty K] 93 dB(A) [3.0 dB]
Batteries Included 2
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 1 mm to 10 mm
Chuck Type keyless
Sound Pressure Level LpA [Uncertainty K] 82 dB(A) [3.0 dB]
Model GSB 12V-15
Drilling Speed 0 - 400 rpm 0 - 1,300 rpm
Impact Rate 0 - 19,500 /min
Length [Front to Back]: 187 mm
Max Drilling Masonry 10 mm
Max Drilling Metal 10 mm
Max Drilling Wood 19 mm
Nett Weight 1 kg (without battery)
Torque 30 Nm
Torque Settings 20 + Drilling
Vibration Drilling Masonry [Uncertainty K] 10.5 m/s [1.5 m/s]
Vibration Drilling Metal [Uncertainty K] 2.5 m/s [1.5 m/s]
Vibration Screwdriving [Uncertainty K] 2.5 m/s [1.5 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 3165140995962
