A great addition to the Bosch 12V family, this compact jigsaw is powerful with variable speed and pendulum action for total cut control whatever the material. Taking standard bayonet fit jigsaw blades, the SDS blade system ensures a quick change. An LED work light is sited directly above the blade to light the work area; the footplate is adjustable for angle cutting up to 45. Battery level indicator fitted. The GST 12V-70 was previously known as the GST 10.8V-LI
Part of the Bosch 10.8V/12V professional Li-Ion family of tools, it is supplied as a body only so that you can utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality and provides the longest possible battery life and runtime.
Supplied as body only.
N.B. Bosch Professional have changed the product name of 10.8V power tools, batteries and chargers to 12V. All Bosch Professional 12V tools are 100% compatible with all current (10.8V) Bosch Professional power tools, batteries and chargers. All 10.8V and 12V tools can be used within the same voltage class system.
Battery Voltage 12 V
Rating Trade/Professional
Stroke Length 18 mm
Sound Power Level LwA [Uncertainty K] 88 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 77 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 5.5 m/s² [1.5 m/s²]
Model GST 10.8 V-LI
Max Depth of Cut Steel 3 mm
Max Depth of Cut Wood 70 mm
Nett Weight 1.95 kg
Pendulum Action Standard Feature
Stroke Rate 1,500 - 2,800 /min
Tilting Base Standard Feature
Vibration Cutting Sheet Metal [Uncertainty K] 5.0 m/s [1.5 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 3165140711463
