This durable, precision screwdriver 43 piece mixed bit set is perfect for both professionals and DIY enthusiasts, for use on site or in the home. The kit includes 20, high quality precision screwdriver bits 28mm and a precision bit magnetic handle - Phillips, SL, Star, U, T, TH, Hex, Y and Triangle. These also attach to the flexible extension bar that is supplied, ideal for reaching awkward areas.
Plus, 20 1/4 insert screwdriver bits 25mm and a standard bit magnetic handle are included, for use in cordless drill drivers and screwdrivers - Phillips, Hex, SL, TH, PZ, U and Y. These are ideal for a broader range of tasks such as assembling furniture.
All of the bits are colour-coded for easy identification. The bits come in a transparent, compact pick-and-click case, for easy and quick storage access.
The kit includes:
20 precision bits 28mm : Phillips - PH000/00/0, T - 2/3/4/5/6, TH - 8, H - 1.5/2, SL - 1.5/2/2.5, Y - 1, U - 2.6, Star - 0.8/1.2, Triangle - 2/2.3
20 1/4 insert screwdriver bits 25mm: Phillips - 1/2/3, PZ - 1/2, TH - 10/15/20/25/30, H - 3/4/5/6, SL - 3/4/6,
Y - 3, U - 6/8
Precision bit handle
Screwdriver bit handle
Flexible extension bar
Pick and click case
Web Attribute Set Screwdriver Bits
EAN Barcode 6949509244871
